3
Toyota Yaris 2018 Service and Repair Manual
Region: General, GCC, South Africa
Format: HTML
Date:
Engine: 1NZ-FE, 2NZ-FE, 1NR-FE, 2NR-FE
Model: Toyota Yaris
Model Code: NCP15#(NCP150,NCP151), NSP15#(NSP150,NSP151)
INTRODUCTION
PREPARATION
SPECIFICATIONS
SERVICE DATA SHEET
MAINTENANCE
Engine / Hybrid System
1NR-FE ENGINE CONTROL
2NR-FE ENGINE CONTROL
1NZ-FE ENGINE CONTROL
2NZ-FE ENGINE CONTROL
1NR-FE ENGINE MECHANICAL
2NR-FE ENGINE MECHANICAL
1NZ-FE ENGINE MECHANICAL
2NZ-FE ENGINE MECHANICAL
1NR-FE FUEL
2NR-FE FUEL
1NZ-FE FUEL
2NZ-FE FUEL
1NR-FE EMISSION CONTROL
2NR-FE EMISSION CONTROL
1NZ-FE EMISSION CONTROL
2NZ-FE EMISSION CONTROL
1NR-FE INTAKE / EXHAUST
2NR-FE INTAKE / EXHAUST
1NR-FE COOLING
2NR-FE COOLING
1NZ-FE COOLING
2NZ-FE COOLING
1NR-FE LUBRICATION
2NR-FE LUBRICATION
1NZ-FE LUBRICATION
2NZ-FE LUBRICATION
1NR-FE STARTING
2NR-FE STARTING
Drivetrain
U340E AUTOMATIC TRANSMISSION / TRANSAXLE
U441E AUTOMATIC TRANSMISSION / TRANSAXLE
CLUTCH
C50 MANUAL TRANSMISSION / TRANSAXLE
C54 MANUAL TRANSMISSION / TRANSAXLE
K312 CVT
K411 CVT
DRIVE SHAFT / PROPELLER SHAFT
AXLE AND DIFFERENTIAL
TIRE PRESSURE MONITORING
TIRE / WHEEL
BRAKE SYSTEM (OTHER)
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
POWER ASSIST SYSTEMS
STEERING GEAR / LINKAGE
Audio / Visual / Telematics
AUDIO / VIDEO
PARK ASSIST / MONITORING
Power Source / Network
1NR-FE BATTERY / CHARGING
2NR-FE BATTERY / CHARGING
1NZ-FE BATTERY / CHARGING
2NZ-FE BATTERY / CHARGING
POWER DISTRIBUTION
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
METER / GAUGE / DISPLAY
MIRROR (INT)
SEAT
SEAT BELT
HEATING / AIR CONDITIONING
POWER OUTLETS (INT)
INTERIOR PANELS / TRIM
Vehicle Exterior
WINDOW / GLASS
DOOR / HATCH
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
HORN
EXTERIOR PANELS / TRIM
New Car Features
INTRODUCTION
SPECIFICATIONS
1NR-FE FUEL
2NR-FE FUEL
1NR-FE COOLING
2NR-FE COOLING
1NR-FE LUBRICATION
2NR-FE LUBRICATION
1NR-FE STARTING
2NR-FE STARTING
Drivetrain
CLUTCH
K312 CVT
K411 CVT
TIRE / WHEEL
BRAKE (FRONT)
BRAKE (REAR)
PARKING BRAKE
AUDIO / VIDEO
NETWORKING
Vehicle Interior
DOOR LOCK
LIGHTING (INT)
SEAT
POWER OUTLETS (INT)
Vehicle Exterior
WINDOW / GLASS
MIRROR (EXT)
WIPER / WASHER
LIGHTING (EXT)
Electrical Wiring Diagram
Introduction
INTRODUCTION
GLOSSARY OF TERMS AND SYMBOLS
WIRE HARNESS REPAIR INTRODUCTION
TERMINAL AND CONNECTOR REPAIR
System Circuit
Drivetrain
Audio/Visual/Telematics
Vehicle Interior
Vehicle Exterior
Location & Routing
Engine Compartment
Instrument Panel
Body
Antenna
Fuse List
Engine Compartment
Instrument Panel
Connector List
Engine Compartment
Instrument Panel
Body
Overall EWD
Drivetrain
Vehicle Interior
Vehicle Exterior
Body Repair Manual
INTRODUCTION
Vehicle Exterior
BODY PANEL
BODY DIMENSIONS
PAINTING / COATING
