Toyota 4Runner FSM 1996 - 2002 Service Manual and Wiring Diagram
Date: 1996 - 2002
Type of Manual: Service Manual, Repair Manual, Wiring Diagram
Model: Toyota 4Runner FSM 1996 - 2002
Number of Pages: 2153 Pages
01 - Introduction
How to Use This Manual
Identification Information
Repair Instructions
Lift and Support Locations
For All of Vehicles
How to Troubleshoot ECU Controlled Systems
How to Proceed with Troubleshooting
How to Use the Diagnostic Chart and Inspection Procedure
Terms and Abbreviations
Glossary of SAE and Toyota Terms
02 - Maintenance
Outside Vehicle
Inside Vehicle
Under Hood
Chassis
03 - Preparation
Maintenance
Engine Mechanical
Emission Control
SFI
Cooling
Lubrication
Ignition
Starting
Charging
Automatic Transmission
Transfer Case
Propeller Shaft
Suspension and Axle
Supplemental Restraint System
Body Electrical
Body
Air Conditioning
04 - Service Specifications
Standard Bolt
Maintenance
Engine Mechanical
Emission Control
SFI
Cooling
Lubrication
Ignition
Starting
Charging
Transfer Case
Propeller Shaft
Suspension and Axle
Body Electrical
Body
Air Conditioning
05 - Diagnostics
ABS w/ EBD & TRAC & VSC System
Cruise Control System
Engine Immobiliser System
Body Control System
Back Door Control System
Air Conditioning System
06 - Engine Mechanical
CO/HC Inspection
Compression
Valve Clearance
Ignition Timing
Idle Speed
Timing Belt
Cylinder Head
Engine Unit (2WD)
Engine Unit (4WD)
Cylinder Block
Exhaust System
07 - Emission Control
Emission Control System
Parts Layout and Schematic Drawing
PCV System
EVAP System
Catalytic Converter System
08 - SFI
SFI System
Fuel Pump
Fuel Pressure Regulator
Injector
Fuel Tank and Line
Mass Air Flow (MAF) Meter
Throttle Body
EFI Main Relay
Circuit Opening Relay
VSV for EVAP
VSV for Canister Closed Valve (CCV)
VSV for Pressure Switching Valve
Engine Coolant Temperature (ECT) Sensor
Vapor Pressure Sensor
Knock Sensor
Air-Fuel Ratio (A/F) Sensor
Heated Oxygen Sensor
Engine Control Module (ECM)
Fuel Cut RPM
09 - Cooling
Coolant
Water Pump
Thermostat
Radiator
10 - Lubrication
Oil and Filter
Oil Pump
Oil Cooler
11 - Ignition
Ignition System
Ignition Coil
Camshaft Position Sensor
Crankshaft Position Sensor
12 - Starting
Starter
Starter Relay
13 - Charging
Charging System
Generator
14 - Automatic Transmission
Operation
Extension Housing Oil Seal
Sensor Rotor
Vehicle Speed Sensor
ATF Temperature Sensor
Park/Neutral Position (PNP) Switch
Vehicle Body Assembly
Parking Lock Pawl
Shift Lock System
Automatic Transmission Unit (A340E)
Automatic Transmission Unit (A340F)
Torque Converter Clutch and Driveplate
15 - Transfer Case
Transfer System
Troubleshooting
Transfer Unit
Transfer Assembly
Oil Pump Body
Driven Sprocket
Rear Output Shaft
Input Shaft
Planetary Gear
Oil Seal
One touch 2-4 Selector System
16 - Propeller Shaft
Troubleshooting (2WD)
Troubleshooting (4WD)
Propellor Shaft Assy (2WD)
Propellor Shaft Assy (4WD)
Spider Bearing
17 - Suspension and Axle
Troubleshooting
Tire and Wheel
Front Wheel Alignment
Front Axle Hub
Front Wheel Hub Bolt
Front Drive Shaft
Front Differential Rear Oil Seal
Front Differential Carrier
A.D.D. Control System
Front Shock Absorber
Front Upper Suspension Arm
Front Lower Suspension Arm
Front Upper Ball Joint
Front Lower Ball Joint
Front Stabilizer Bar
Rear Axle Shaft
Rear Wheel Hub Bolt
Rear Differential Front Oil Seal
Rear Differential Carrier
Differential Locking System
Coil Spring and Rear Shock Absorber
Rear Lateral Control Rod
Rear Upper and Lower Control Arm
Rear Stabilizer Bar
18 - Brakes
Brake System
Troubleshooting
Brake Fluid
Brake Pedal
Parking Brake Lever
Front Brake Pad
Front Brake Caliper
Rear Drum Brake
Hydraulic Brake Booster
Front Speed Sensor
Rear Speed Sensor
19 - Steering
Steering System
Troubleshooting
Drive Belt
Power Steering Fluid
Steering Wheel
Non-Tilt Steering Column
Power Steering Vane Pump
Power Steering Gear
20 - Supplemental Restraint System
SRS Airbag
Steering Wheel Pad and Spiral Cable
Front Passenger Airbag Assembly
Airbag Sensor Assembly
Front Airbag Sensor
Wire Harness and Connector
21 - Body Electrical
Body Electrical System
Troubleshooting
Power Source
Ignition Switch and Key Unlock Warning Switch
Headlight and Tailight System
Fog Light System
Turn Signal and Hazard Warning System
Interior Light System
Back-Up Light System
Stop Light System
Wiper and Washer System
Comination Meter
Defogger System
Power Window Control System
Back Door Power Window Control System
Power Door Lock Control System
Theft Deterrent System
Wireless Door Lock Control System
Sliding Roof System
Power Seat Control System
Power Mirror Control System
Seat Heater System
Audio System
Antenna
Clock
Garage Door Opener System
22 - Body Mechanical
Clip
Front Bumper
Rear Bumper
Hood
Front Door
Rear Door
Back Door
Back Door Stay
Front Wiper and Washer
Rear Wiper and Washer
Body Outside Moulding
Wheel Arch Moulding
Windshield
Quarter Window Glass
Sliding Roof
Instrument Panel
Roof Headlining
Side Step
Front Seat (Separate Type)
Front Seat (Sports Type)
Front Seat (Power Adjuster
Type)
Rear No.1 Seat
Rear No.2
Seat
Seat Belt
Seat Belt Pretensioner
23 - Air Conditioning
On-Vehicle Inspection
Evacuating
Charging
Location
Troubleshooting
Drive Belt
Manifold Gauge Set
Refrigerant Line
Cooling Unit
Heater Unit
Rear Heater Unit
Blower Unit
Compressor and Magnetic Clutch
Receiver
Condenser
Water Valve
Blower Motor
Blower Resistor
Blower Motor Linear Controller
Rear Blower Resistor
Air Inlet Servomotor
Air Outlet Servomotor
Solar Sensor
Room Temperature Sensor
Ambient Temperature Sensor
Pressure Switch
Heater Main Relay
Rear Heater Relay
Extra-Hi Relay
Air Conditioning Control Assembly
Heater Control Assembly
Rear Heater Control Assembly
Rear Blower Switch
24 - Wiring Diagrams
A - Introduction
B - How to Use this Manual
C - Troubleshooting
D - Abbreviations
E - Glossary of Terms and Symbols
F - Relay Locations
G - Electrical Wiring Routing
H - System Circuits
I - Ground Point
J - Power Source
K - Connector List
L - Part Number of Connectors
M - Overall Electrical Wiring Diagram
DHT-toyota-4runner-fsm-1996-2002-service-manual-and-wiring-diagram-18393823022025-1.jpg101.9 KB · Views: 150 -
DHT-toyota-4runner-fsm-1996-2002-service-manual-and-wiring-diagram-18393823022025-2.jpg204.9 KB · Views: 135 -
DHT-toyota-4runner-fsm-1996-2002-service-manual-and-wiring-diagram-18393823022025-3.jpg140.6 KB · Views: 137
