DHTAuto Support
270
71
31
Singapore
Hitachi MPDr Ver3.5.0.0_JD
Description: Hitachi Construction Machinery MaintenancePRO MPDr version 3.5.0.0 is intended for diagnostics of construction. Also, the program is diagnoses with the engine, hydraulic system and bodywork. In addition to diagnostics, the program is designed to read and erase errors, change the basic values of the engine speed, exhaust valve pressure, current parameters and much more. On our site only diagnostic software without an adapter is provided.
Type of software:
Diagnostic Software
Capacity: 50.3MB
Version:
3.5.0.0
Brand: Hitachi
Region: All region
Language: English, Japanese, Spanish, Portuguese
OS : Windows 7, 8, 10 32/ 64 bit
Hard Drive: Free 20 GB or more (recommend use SSD drive)
CPU: Intel Core I3 gen 2 and up
RAM: 4 GB or more
Software Feature:
You can set or check the next parameters:
The operation of the engine
The settings of the control of the machine
The settings of the monitor
Change or check the settings of the information controller and communication terminal
Change or check the settings of others function
Hitachi Construction Machinery MaintenancePRO MPDr has the following functions:
Monitoring System
This system allows dealers to monitor information about hydraulic pressure, Hydraulic Oil Temperature, Actual Engine speed, etc., that is sent from sensors or switches.
Troubleshooting function
This system allows dealers to check failure codes occurring in the electric system. If any error code occurs, the system will display the error code, the meaning of the error code and the necessary corrective action.
This information is sent from sensors or switches to the monitor for further diagnostics. All these functions help the service master and owner check the fault codes that occur in the electrical system. If errors occur, the program disnlavs the error rode the error value and offers the necessary corrective action.
Supported models:
Hydraulic Excavator (6 ton-under 40 ton)
EX-3 or earlier
EX-5
ZX-1 (C-series)
ZX-3 (D-series)
ZX-5 (G-series)
ZX-6 (G-series)
Mini Excavator (Under 6 ton)
MC (OPT)
Mining Excavator (over 100 ton)
EX-1
EX-5
EX-6
EX-7
EX1200-6
EX1200-7
Dump Truck
Rigid dump (AC2)
Rigid dump (AC-3)
Rigid dump (EH-3, EH-5)
Wheel type hydraulic excavator
ZXW-6 (G-series)
ZXW-5 (G-series)
ZXW-3 (D-series)
ZXW-1 (C-series)
EXW-3 or earlier
Large excavator (40 ton-under 100 ton)
ZX-6 (G-series)
ZX-5 (G-series)
ZX-3 (D-series)
ZX-1 (C-series)
EX-5
EX-3 or earler
  • HITACHI MPDr 3.5.0.0.txt
